Canon ir adv c5235i
  • zuckryyu
    • Jul 2019
    • 34
    [CQ] Canon ir adv c5235i
    Can someone tell me what cause this ... density suddenly high
    Sent from my TA-1021 using Tapatalk
  • mosey1100
    • Mar 2009
    • 143
    Re: Canon ir adv c5235i
    It has something to do with the ATR Control area of the copier. You could have a faulty Patch Sensor or it could be dirty. Are you getting any error codes?
    • zuckryyu
      • Jul 2019
      • 34
      Yes,after a few printing i keep getting code e020-0103...i already clean the patch sensor but, still getting the code sometime...is there any way to get the density to normal value?
      • wcanonw
        • Aug 2014
        • 404
        Description The value is higher than the upper limit for the patch.
        Remedy Go through the following: DISPLAY > P-LED-DA; perform
        cleaning first If P-LED-DA is 3F or more.■
        1. Check installation of the Developing Assembly and the
        Drum.■
        2. Clean the Patch Sensor (UN47,UN48,UN49) Window.■
        3. Check if the patch sensor is disconnected.■
        4. Replace the Patch Sensor.■
        5. Replace the Drum.
        • wcanonw
          • Aug 2014
          • 404
          Send photo of test page 10 and test page 6 to see the status of developers.
          if you have cleaned the patch sensor, perform developer initialization
          Initialization of Developing Assembly (toner ratio and patch) is necessary and it differs
          depending on the color.
          If 4 colors are replaced simultaneously, execute INISET-4.
          COPIER > FUNCTION > INSTALL > INISET-Y Initialization of Y Developing Assembly (toner
          ratio and patch)
          COPIER > FUNCTION > INSTALL > INISET-M Initialization of M Developing Assembly
          COPIER > FUNCTION > INSTALL > INISET-C Initialization of C Developing Assembly (toner
          ratio and patch)
          COPIER > FUNCTION > INSTALL > INISET-K Initialization of Bk Developing Assembly
          COPIER > FUNCTION > INSTALL > INISET-4 Initialization of 4-colors Developing
          Execute the following in user mode: (Settings/Registration > Adjustment/Maintenance >
          Adjust Image Quality > Auto Adjust Gradation).
          • wcanonw
            • Aug 2014
            • 404
            check if the shutter and selenoid of the patch sensor is activating well
            • zuckryyu
              • Jul 2019
              • 34
              Thanks sir, apparently the shutter not moving well...and replaced...it works fine now
