IR 5020
  • xcopytech
    • Aug 2006
    • 1794
    IR 5020
    replaced primary corona wires and cleaned primary grid but stil have problem with CQ.
    when adjust primary corona wires at normal height, at both side get little background which look like small dark lines.
    when remove corona wires near to grid get clear print/copy but it is too dark.
    could grid be a problem.
    corona wires are Canon original.
  • SCREWTAPE
    • Sep 2025
    So you restrung the primary corona ass'y? I usually replace the whole primary corona, along with the pre transfer corona and transfer separation corona ass'y. When I start seeing dark bands, white bands, over-toning backgrounds I replace those parts ; Saves time, and nine times out ten it works like a charm. Also check potential control.
    What the count on the machine?
    • xcopytech
      • Aug 2006
      • 1794
      • alex@wocltd.com
        • 430
        • Oze
          Ricoh Fanboy
          • Jul 2008
          • 1663
          Agreed...time to try a new Primary coro
          • xcopytech
            • Aug 2006
            • 1794
            THANKS
            • Canuck
              Tech Specialist
              • 1713
              Check to make sure seal glass in laser path is clean...clean all optics and white plates...do ccd adjust...does it do it on copies and prints? Make sure pre-exposure lamp is working and clean
              • time2fly
                • Jul 2008
                • 134
                before you put the new parts in make sure all is well with the components. I have replaced PRI. Corona and transf. units before and CQ was still a problem. I removed the new units to found that the wire on the pri. unit wasn't in the right place. just a cya thing for you.
