Canon IRC5250 data missing when scanning
  • skibum
    Independent Service Tech
    • 233
    This Canon IRC5250 intermittently voids out most of the page except for the edge on one side or the whole image is blank.
    Please through out your ideas as I need help.
    Thank you folks and stay safe!
  • skibum
    • 233
    Re: Canon IRC5250 data missing when scanning
    Please throw out your ideas. Typo.
    Thank you!
    • guitar9199
      • Sep 2016
      • 1100
      First thing I would do is update the firmware.
      • giogi
        Engineer senior
        • Jan 2016
        • 181
        R-CON CLEAR
        Check condition of CCD's flat cable
        "Knowledge is a source, but unfortunately ignorance is a sea."
        • copier tech
          • 8169
          Does this issue occur only on scanning or when copying also?
          • Canuck
            Tech Specialist
            • 1713
            Through feeder? Off the glass? Need more info....
            • copier tech
              • 8169
              Exactly limited info not much help 🙄
              • tech28
                • Jun 2013
                • 434
                Delivered one, about month ago, customer called next day, scanning only half a copy, single side only, not when duplexing, replaced feeder from parts 5250, problem solved, had to charge them, feeder dropped too hard, scanning optical damaged on feeder. As for your problem, is it one sided? Or duplex side?
