Canon c5235a new hard drive software
  • mga
    Copier Technician
    • Dec 2010
    • 1393
    #16
    Re: Canon c5235a new hard drive software
    Originally posted by jio9000
    the hard drive is usual locked when placed into a canon machine , is there away for me to format it and use it in my pc, i place a normal one in the immage runner c5235a also and it locked it, pc cant access needs password, is there away for me to format and use again in my pc, thanks much in advance.
    If you have a irac52xx and you take a hard drive from another irac52xx it will work you can for or repair hdd from copier but don't think you can from pc
    Regards Mark
    • copier tech
      • 8176
      #17
      Yes you can delete all the partitions then format & use in your PC.
      • copytech,mike
        CopyTech,MIKE
        • Jun 2014
        • 261
        #18
        Originally posted by spectraindo
        Unfortunately you cannot clone the hard drive on the C52xx series, it will report a bad disk.
        The only way is get a USB stick with System Software for the machine or use SST with a PC.
        I agree. The old SST is obsolete. All firmware is now upgraded VIA USB flashdrive period. You can only get the Firmware from a Canon dealer. My buddy at a Canon dealer emailed me the firmware and i plased on on a flashdrive. Its still a little tricky. The actual firmawre itself must appear at the very top of the list on your flash drive. Power Up 28 and hit "download all". Works like magic.
        • copytech,mike
          CopyTech,MIKE
          • Jun 2014
          • 261
          #19
          You dont know what the hell your doing. This is not a Konica Minolta. Theres no internal formatt function. You must place a new HDD from Cannon and then do a firmware update VIA flash drive. Your only other option is to purchase a used Canon HDD from Ebay that was pulled from a known working machine. Canon is different. You must know what the fuck you are doing.
          • copier tech
            • 8176
            #20
              +2 to this statement.
