Broken Glass Screen of Control Panel Unit IR 4545
  • maxcopiers
    • Dec 2019
    • 15
    Hello, I have a Canon IR 4545 machine that has a broken/cracked glass in the Control Panel Unit. Where can I purchase a replacement Control Panel Unit? Also, if possible, is there a way to replace just the broken glass instead of the entire Control Panel Unit?
  • copier tech
    • 8107
    Re: Broken Glass Screen of Control Panel Unit IR 4545
    Is this the new IRADv 4545 series?
    • Brian8506
      • 1658
      Nationwide in Kansas lists the panel with limited repair and the LCD but the touch screen may be an issue. Also quite expensive
      • maxcopiers
        • Dec 2019
        • 15
        Yes, I believe so, IR Advanced 4545i. It is white.
        Parts
        Cover frame: FE4-1774-020
        LCD Unit: FM1-R334-000
        • mga
          Copier Technician
          • Dec 2010
          • 1393
          Top screen is included with the top white cover if the lcd under the top screen looks damaged you may be ok as the lcd is the expensive part. But the only way to know is to remove top panel
          Regards Mark
