Canon iR Advance 6255 BootableDL Project Error
  • Mirzano13
    • Jan 2020
    • 11
    [Dead] Canon iR Advance 6255 BootableDL Project Error
    Hi, i need help my machine won’t start to download mode, when i powered on and hold 2 & 8 key, the system says BootableDL Project Error, before it happens,i went format hdd (all) but when in the middle of the process, the machine suddenly shuts, and when i try to enter download mode again, it happens.
    anything solution to solve the problem?
    it would be helpful
    thanks
  • copier tech
    • 8192
    Re: Canon iR Advance 6255 BootableDL Project Error
    Originally posted by Mirzano13
    [ATTACH=CONFIG]45885[/ATTACH]
    You have an issue with the ssw on the HDD or the HDD could be failing.
    Try reloading the SSW before replacing the HDD.
    • Mirzano13
      • Jan 2020
      • 11
      How can i reloading ssw when download mode is not available?
      thanks for replying btw
      • copier tech
        • 8192
        What happens if you try & start the machine normally?
        • Mirzano13
          • Jan 2020
          • 11
          It cause error E748-2012
          it could possible on flash sata pcb?
          anything to recover flash pcb if it was the issue?
          thanks
