Canon C3325i - Setup Failed
  • Martinus
    • Jul 2020
    • 2
    Our Canon copier reboot and don't start anymore ..
    No more acces to the configuration
  • alex@wocltd.com
    • 430
    Re: Canon C3325i - Setup Failed
    weird quirk with these 33xx - easy fix with new hdd and firmware, before i get flamed - spent too long on these trying to format and recover the hdds when you can pick up the hdds for 10/20 quid....
    have had some luck back at base recovering the older hdds.....
    • mga
      Copier Technician
      • Dec 2010
      • 1393
      Regards Mark
        exactly?
        i thought you had to use a 'canon' approved HDD?
        • mga
          Copier Technician
          • Dec 2010
          • 1393
          exactly?
          You do
          Regards Mark
          • alex@wocltd.com
            • 430
            dont know how to break it to you guys - HTS545050A7E380 | eBay
            currently 57 hdds under 20 quid.....
            Canon 'hdds' are NOT anything special - they become special when formatted and loaded with firmware.....
            you can go one step further and get ANY hdd and clone existing hdd to it - but remember you cannot preload hdd(for latest models)....but now hdds are so cheap it aint worth the effort
            hope this helps
            • copier tech
              • 8174
              [ATTACH=CONFIG]46135[/ATTACH]
              Start with the basics by reloading the firmware before you start replacing an unnecessary HDD!
              • copier tech
                • 8174
                hope this helps
                You can not simply use ANY HDD even if it is the same size.
                However simply buy an identical hard drive model that you currently have in the machine this will work as Canon have a set list of specific HDD models that you can use.
                Back in the day you could edit the firmware but now it is encrypted.
                • alex@wocltd.com
                  • 430
                  and the problem with this as stated earlier is you get 80% the way through and it fails as stated a weird quirk so it is quicker to swap out HDD in field and start a fresh,you can then try to recover HDD back at workshop...factor in parking costs in London this proves to be better by far economically.....
                  • alex@wocltd.com
                    • 430
                    Your taking my reply out of context - as long as you ghost or clone you can use any size as long as it is the same or bigger ....
                      MMI clear and then try the setup again?
                      • alex@wocltd.com
                        • 430
                        From the pictures supplied they are stuck in a boot loop so can't get into svc mode
                        • Martinus
                          • Jul 2020
                          • 2
                          Do you know how to do it when it doesn't start ?
                          Nothing on the user manual ... always "please call Canon Assistance ..."
                          • giogi
                            Engineer senior
                            • Jan 2016
                            • 181
                            please explain step by step the procedure
                            thanks
                            "Knowledge is a source, but unfortunately ignorance is a sea."
                            • copier tech
                              • 8174
                              Poster does not say anywhere he has tried to reload the SSW so he has nothing to loose in trying.
