ir-4570
  • T911
    • Jun 2007
    • 628
    ir-4570
    jam rite at the pre reg switch out of all the trays but bypass. after i took the right side of the machine apart just to get the upper feed unit out to reinstall the flag that came out it still jams. when removing the feed unit the back of the base was loaded with toner, cl-all the sensors in the feed unit but no luck. i managed to get a couple through to q3 but i can't watch anything on this one. flag maybe worn down?? 717k on this one. help appreciated.
  • SCREWTAPE
    • Aug 2025
    Have you try changing the lower door B, inner door guide assy (New type) , the vertical path rollers and the separation & feed rollers, plus the reg roller. Also the DC controller should be updated. This helps my older iR3570/4570's. I experience toner dropping down to the onto the Pick up ass'y and around registration, it usually gets on the rear of the registration roller; The toner Spills from the sub hopper.. Canon came out with some seals to remedy that problem. Hope this helps,
    Screwtape.
    • pspahr
      Toner Schlep
      • May 2008
      • 227
      Also, I've seen the reg sensor get stuck. The sensor arm moves from the center of the path to the rear of the machine. There is a stopper bracket that has a foam pad on it. The pad gets sticky and when the flag moves it gets stuck momentarily. I simply scrape the faulty pad off and voila, no more jams. Although I am not sure we're talking about the same sensor.
      VectorLinux---Check it out!
      • T911
        • Jun 2007
        • 628
        haven't changed door b or the inner guides but i repl-pf tires for lct and 2 trays. whats up with the dc controller. thanks guys
        • chrisb19036
          • Jul 2008
          • 16
          hey t911, I'm sure screwtape hit it on the head with this one. the vertical path rollers have been updated for this particular issue and canon came out with a modification for the lower feed door. there is foam pads that you insert onto the door to inc. pressure. this has stopped many jamming problems in the past for me. hope this helps.
          • Oze
            Ricoh Fanboy
            • Jul 2008
            • 1663
            What's the jam code?
            Does the machine LCD display a jam at the fuser constantly?
            If so then yes...it's the pre registration flag.
            0105/0107 jam codes are usually fixed by replacing the vertical path roller with the new type(grey color).
