Canon C1022i scanning ?
  • mrfuser
    • 1617
    Does anyone know if you can scan to folder or email with a C1022i ? I don't normally work on these and a client has been given one for his home office. Brochure says it can push scan, but I don't see how.
    Thanks all!
    K
  • mrfuser
    • 1617
    Re: Canon C1022i scanning ?
    anyone? No gurus left for Canon here anymore?
      did you look on the canon site for specs pertaining to scanning?
      do you have a manual for this ( you will need it )
      what system are you trying to push the scan to?
      is firmware up to date on this model?
      care to explain what you have tried?
      • mrfuser
        • 1617
        When I log in to the remote UI I can see nothing to set up smb or email scanning. What is the purpose of it being an "i" system if not for that?
        Yes it has latest firmware on it.
        I have downloaded pull scan software and drivers for the client
        • copier tech
          • 8138
          Thanks all!
          K
          If i remember correctly you need to install Network ScanGear then you can pull scan.
          • mrfuser
            • 1617
            • copier tech
              • 8138
              Yes isend model you can scan via email & SMB also.
              • mrfuser
                • 1617
                ok, do we need to get into seevice
                mode to turn that on?
