Canon ir5050 vertical black stripe on edge
  • ernesto2019
    • Jul 2019
    • 14
    [Misc] Canon ir5050 vertical black stripe on edge
    when I copy through the ADF I get that black line and when I copy through the glass it doesn't give me that problem
    Re: Canon ir5050 vertical black stripe on edge
    run ADF adjustments...
    is it copying at 100%?
    all guides tight on originals ?
    • ReproKev
      • 273
      Clean the small glass to the left of the main copyboard glass. It probably has whiteout on it.
      • Brian8506
        • 1665
        Looks like a bad skew
        • 1stcavvet
          • Apr 2015
          • 231
          If you did't find it yet look for something hanging down just under the slit between the slit glass and main glass
          • Brian8506
            • 1665
            I think it's so badly skewed that it's copying the edge of the paper. I would check the position of the ADF
            • ernesto2019
              • Jul 2019
              • 14
              I already cleaned the glass and the ADF and I always get the black streak on the edge
              • Brian8506
                • 1665
                • mga
                  Copier Technician
                  • Dec 2010
                  • 1393
                  This is a skew problem check side guide and DF unit is not skew on machine and check hinges.
                  There is a skew adjustment for the df
                  Regards Mark
                  • ernesto2019
                    • Jul 2019
                    • 14
                    So I get the copy, I already cleaned ADF, the glass and I do not know what guide I can review
                    • ondemandprint
                      • Sep 2016
                      • 87
                      Just see on ADF unit VERY attentively. Is it fully parallel with the glass of the scanner? It can be so that ADF unit is skewed relatively by the glass.
                      • ernesto2019
                        • Jul 2019
                        • 14
                        I tried everything and finally it starts to change some values ​​in service mode
                        copier / adjust / adj xy /
                        I started to change the values ​​and when I give it OK, I get the error 225, I clear the error and then I turn on the copier and then enter the default values ​​that had changed and it worked for me, it does not give me the problem of the black line in the edge
                        I do not know what happened !!!!
