Canon 2016/2018/2020 info
Selous
really need service manual for iR2016
Dear all,
I really need the service manual for Canon iR 2016. Can somebody please help me.
Many thanks in advance!Comment
This is the forum specifically set up for requesting service manuals, you might try there..."Once a King, always a King, but once a Knight is enough!"
Two posts and you ask free documents ??
is the USA it's all about the money/ Manuals cost money/
trained techs put in hours of training & money to receive documents**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
Hi Mike,
Not 30 minutes after I posted to the last person that manual requests should be made in a specific forum, you posted a request for a manual... Did you bother to read my post, and see the link that would have taken you to the correct forum?"Once a King, always a King, but once a Knight is enough!"
civilengineeribrahim
I also need firmware & SST for canon IR2016j.
Could you please send me via civilengineeribrahim@yahoo.com
Many thanks.Comment
Many thanks."Once a King, always a King, but once a Knight is enough!"
SAKTHI
dear sir
on my canon ir 2016 tells "drum not set insert drum" i have checked the and change the whole drum unit still tells the same message, and then i have changed the sensor the message still appear pls tell how can isolve this problemComment
Check & clean the high voltage contact to the drum unit
Check the ribbon cable between the DC Controller and the HVT PCB**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
migaa_ts
about 2018 service manual
I'm in need of service manual of iR2018.
Can you send me one ?
migaa_ts@yahoo.comComment
