Ir 3235 canon
  • aakash2411
    • Dec 2013
    • 17
    [CQ] Ir 3235 canon
    Facing this issue in ir 3235 .I have replaced drum unit and developer unit but still same issue.
    The developer unit was not rotatating at first .I had to remove motor assembly section and fixed same after inspection.
    DP unit know runs but copy quality has back ground and black dots.
  • Brian8506
    • 1666
    Re: Ir 3235 canon
    Still looks like a drum pattern. Could be the hvt. I only had to replace one but the symptom was similar
    Sent from my iPad using Tapatalk
    • Kkh
      • Jul 2020
      • 7
      Re: Ir 3235 canon
      Change your HVT . For the black dots, remove all the ink in developing then rub a little alcohol on the magnet roll slowly do not press too much when wiping it. just float while rotating
      • aakash2411
        • Dec 2013
        • 17
        Re: Ir 3235 canon
        Hi
        The problem has solved .the issue was main motor gear unit.i was creating trobles.
        Thank u all
        • Kkh
          • Jul 2020
          • 7
          Re: Ir 3235 canon
          Hi
          Thank u all
          Ok. Have a nice day
