Is there a master master here who has a flow chart from the Canon IR 4570 power supply, I have a case of a total dead machine, all parts of the power supply, mainboard, DC control, etc. have been replaced, still no movement at all
ir 4570 total dead machine
Re: ir 4570 total dead machine
Have you replaced all the electronics on the power board and don't have the correct outputs? -
if you have the green LED on, in the technical manual Rev.10, in chapter 6 Troubleshooting, there is the chapter Startup System Failure Diagnosis, you will find a flowchart for your problem."Knowledge is a source, but unfortunately ignorance is a sea."Comment
I have changed all electronics, but it's still the same, I want to know the current coming out of the power supplyComment
Another possible question what happens when you switch on the machine? Do notice any hissing sound indicating the presence of power,is the circuit braker at the back of the machine turned on?
if so critically look at the wiring of any possible damagesComment
