Cleared ALL by mistake
  • princepriyu
    hi,
    I am using Canon IR3300 Photocopier
    while clearing an error from internal service settings, my assistant cleared ALL (Following)
    ERR
    DC-CON
    R-CON
    SERVICE
    now problem is, it is not printing anything, just a white page is passed by,
    when looking it deeply i can find very light image.
    but in reverse,
    while printing configuration page, its printing letters in black and background white,
    while originally it must be background in black and letters white
    what should i do to correct
    please any suggestions or where to look . . . .
  • oombees
    • Apr 2016
    • 27
    Re: Cleared ALL by mistake
    You need to enter service mode and insert the values listed on the inside of the door. When you cleared all you also reset the laser values.
    Sent from my SM-G985F using Tapatalk
    • Brian8506
      • 1664
      • princepriyu
        thanks for the reply
        but unluckly i do not have any note or default values on my door
        • oombees
          • Apr 2016
          • 27
          Which model?
          • princepriyu
            Which model?
            Oopss
            • princepriyu
              Yes sir, this machine was recently brought from another location
              and it was in a very bad condition
              • oombees
                • Apr 2016
                • 27
                Values should be listed on the inside of the front cover. You need to remove it to find the values label
                  • 8144
                  Originally posted by princepriyu
                  hi,
                  ERR
                  DC-CON
                  R-CON
                  SERVICE
                  but in reverse,
                  You are talking about the old mono IR3300 ?
                  I used to clear all these vales on every one I sold, it will NEVER give you print quality issues after.
                  Did you test the print quality BEFORE you cleared these vales?
                    • 16083
                    ??? What is this statement ?
                    Are u a tech ?
                    if missing --get a service manual to view basic settings and adjustments
                    under
                    COPIER>ADJUST
                    COPIER>FUNCTION
                    COPIER>OPTION
                    PRINT OUT A NEW SERVICE LABEL
                    COPIER>FUNCTION>MISC-P>LBL-PRNT
                    • princepriyu
                      Thanks for the reply
                      the problem is there is no such LABEL inside the machine
                      when i am trying to print it as per your guidence i get a white page
                      because this is not PRINTING any thing
                      that is my problem . . . .
                      • Brian8506
                        • 1664
                          • 16083
                          First, let's start here🤔
                          Do u have any images on paper from glass copies ?
                          if No, u have a problem.
                          If yes,
                          Now, If printer is connected to network, send over to test printing.
                          Report back .
                          • COPIERTEC ASSOCIATES
                            • Aug 2011
                            • 279
                            hi,
                            ERR
                            DC-CON
                            R-CON
                            SERVICE
                            but in reverse,
                            What was the initial problem before you cleared the erro
