Canon c5045
  • copier tech
    • 8193
    #16
    Re: Canon c5045
    Originally posted by omkara1234
    Need firmware. I got sst 4.83. Irc adv c5045
    Happy to help drop us an email
    www.copierfirmware.co.uk
    • teckat
      • 16083
      #17
      Re: Canon c5045
      Also this is canon machine itself. OEM HDD firmware already installed by canon themselves. All i would be doing is registering firmware i.e. creating certificate. Which wont be copyrighr issue at all. Also i am otherwise lawyer by profession and won't indulge into reselling firmware. This is for my personal use. I can guarantee that and take full responsibility for legality of my acts.
      Possible Firewall issue
      HTTP traffic is being blocked before getting to the device.
      • teckat
        • 16083
        #18
        Re: Canon c5045
        Copier > Option > FNC-SW > CDS-UGW and set it to "1"
        These settings are in the same service mode location as CDS-UGW and are defined as CDS-Firm and CDS-MEAP.
        Configure CDS for Scheduled Firmware Update for Canon Controllers?
        The copier can download and install System Software automatically by following these steps:
        1) Service Mode Level 1
        2) Select Copier
        3) Select Option
        4) Select FNC-SW5)
        Enter 1 for each of the following:
        CDS-FIRM
        CDS-UGW
        CDS-LVUP
        6) Press Ok
        7) Reboot the Copier.
        8) Your Screen should now have a Schedule Update section.
        You can access this by:
        a) Settings/Registration.
        b) Login in as System Manager and password.
        c) Select Management Settings
        d) Select License/Other
        e) Select Register Update Software
        f) Select [Schedule Update] settings and change to ON
        g) For [Update Schedule], you MUST select either Weekly or Biweekly and, the day of the week, as well as military time.
        h) For [Apply at] select military time and press OK.
        • omkara1234
          • Jan 2021
          • 24
          #19
          Re: Canon c5045
          [QUOTE=teckat;1672450]
          2) Select Copier
          3) Select Option
          4) Select FNC-SW5)
          CDS-FIRM
          CDS-UGW
          CDS-LVUP
          6) Press Ok
          Thank you so much for your contribution.
          Unfortunately I tried what is shown dot---- to dot.. instructions. however the communication with server is not getting through because of error --- certificate get configuration error code 8202 4206.
          still searching for correct answer.
          I tried to install private key from digitalcertificate.com and it dont work either. generated own key with SHA512 and 2048 but it wont work either.
          • teckat
            • 16083
            #20
            Re: Canon c5045
            [QUOTE=omkara1234;1674416]
            2) Select Copier
            3) Select Option
            4) Select FNC-SW5)
            CDS-FIRM
            CDS-UGW
            CDS-LVUP
            6) Press Ok
            Ok
