Canon IR 3570 blurred pages (double vision)
  • CopierChick
    • Aug 2012
    • 85
    I have a Canon IR 3570 with blurred pages (not ghosting) more like double vision, as seen in the attached image. I have cl
  • copier tech
    • 8131
    Re: Canon IR 3570 blurred pages (double vision)
    Looks like a fuser smudge, what is the life of the fuser sleeve?
    • COPIERTEC ASSOCIATES
      • Aug 2011
      • 279
      1.Check on the sleeve(lower roller) on the fixing unit.
      2.Check the cleaning metal roller just below the sleeve roller it could be coated with a crust of toner.
      3.When you send a self print copy is it also blurred if so concetrate on 1and 2 above,if the self print copy is ok check on the scanner.
      • GIUBOSS
        • 1391
        stop printing / copying before it reaches the fuser and check the page, you will know if the problem is in the pcu or in the fuser.
        • zoraldinho
          teacher-guide-expert-guru
          • Mar 2008
          • 5007
          Fuser or poor ground door contact.
          • copier tech
            • 8131
            You can't check the fuser sleeve, visually it may look OK.
            You need to replace the film ass'y, cleaning & pressure rollers.
            However being from Kampala I guess you are rebuilding the fusers?
            • CopierChick
              • Aug 2012
              • 85
              It was the fuser fixing film causing the issue. I had already replaced it for the same issue with a rebuilt unit but looks like the rebuilt one had an issue also. Thanks for the help
              • copier tech
                • 8131
