Getting error after replacing the main controller PCB:
  • x3256
    • Feb 2021
    • 22
    [Dead] Getting error after replacing the main controller PCB:
    I have replaced the main controller PCB with a recently bought refurbished controller now after replacing its giving error e355. Machine is irADV8105, then i noticed that the board belongs to irADV8095, it is just controller PCB without counter and giving error even though the irADV8105/8095 belongs to same series, is there any way to fix this.
    Thanking you.
  • copier tech
    • 8172
    Re: Getting error after replacing the main controller PCB:
    Thanking you.
    No you can't swap the DC controller from the wrong machine.
    • x3256
      • Feb 2021
      • 22
      Refurbished main controller is in working condition, it seems like its impossible to even install controllers from copier of same series to another, is there any way, im only swapping the controller not counter and serial, since the old one is faulty.
      OR i cannot swap main controllers from irADV8105 to 8095.
      Thanks a lot.
        They are different part numbers although as far as I am aware that would not cause a 355 error
        FM4-5303-010 MAIN CONTROLLER PCB ASS'Y, iR-ADV 8085
        FM4-5304-010 MAIN CONTROLLER PCB ASS'Y, iR-ADV 8095
        FM4-5305-010 MAIN CONTROLLER PCB ASS'Y, iR-ADV 8105
        • x3256
          • Feb 2021
          • 22
          yes i got fm4-5304-010 since fm4-5305-010 was not available and tried to replace with faulty one and it got booted but shows error e355 although im using its original counter and serial, both controllers are identical in hardware.
          Thanks a lot!
            Thanks a lot!
            I don't have much info on that model but apparently you get 355 if you use the wrong main controller on the iradv5xxx models, so would assume its a similar situation you have.
            • copier tech
              • 8172
              Why are you replacing the DC controller, what is wrong with the original one?
              • x3256
                • Feb 2021
                • 22
                Original one is faulty, it shows nothing not even boots, that's why bought another. I thought series is same thats why bought another but it happens to be for irADV8095 model and the faulty one is for 8105.
                • nicknt82
                  • Nov 2011
                  • 155
                  If error E355 that mean original mainboard fault. Replace correct new maincontroller will solve it. If you want to solve e355, replace main pcb with counter,id pcb sametime or event dc controller
                  • Dada Alla
                    • Nov 2022
                    • 2
                    Hello, I have a problem with a Canon Advance 8105 photocopier. It has an error 733. A
                    Hello, I have a problem with a Canon Advance 8105 photocopier. It has an error 733. Also, the motors do not work at all. Is there a solution for it? Where is the defect and how is it repaired?
