canon IR advance C2225
  • tcypy1961
    • 773
    [CQ] canon IR advance C2225
    what would be causing the black unit to crap out so soon. I followed installation procedure. I was called out because customer said copier was calling for cyan toner. the following samples are what I found. removing the black imaging unit I saw the same thing that I did back in Feb. 2020; unit wasn't replaced till Sept. 2020. In Feb. 2020 black unit had just shy of 47,000 copies; did not get present count.IMG_0047.jpgIMG_0048.jpgIMG_0049.jpg
    Thanks!!!
    P.S. the order the samples were the order they were made.
  • Brian8506
    • 1665
    Re: canon IR advance C2225
    47000 is good yield. Those black drums are not very good
    • tcypy1961
      • 773
      the 47,000 was 1st replacement I'm thinking less than that on replacement yet I forgot as I stated to get copy count. I don't work on color copiers so trying to figure out is it what you are saying or something else.
      Thanks!!!
      • Brian8506
        • 1665
        • copier tech
          • 8174
          Originally posted by tcypy1961
          what would be causing the black unit to crap out so soon. I followed installation procedure. I was called out because customer said copier was calling for cyan toner. the following samples are what I found. removing the black imaging unit I saw the same thing that I did back in Feb. 2020; unit wasn't replaced till Sept. 2020. In Feb. 2020 black unit had just shy of 47,000 copies; did not get present count.[ATTACH=CONFIG]48523[/ATTACH][ATTACH=CONFIG]48524[/ATTACH][ATTACH=CONFIG]48525[/ATTACH]
          Thanks!!!
          One of the worst models Canon made for drum life.
          Not seen that test chart in what must be 20+ years!!!
          • zoraldinho
            teacher-guide-expert-guru
            • Mar 2008
            • 5015
            Sometimes just reinstalling the same drum solve the problem on this series.Not good model.
            • mga
              Copier Technician
              • Dec 2010
              • 1393
              Thanks!!!
              New Black drum needed don't rebuild just oem new oem unit if you get errors make sure you clean id sensors and laser
              Regards Mark
              • nochick
                • Jan 2012
                • 80
                Some unit has a shorter life span, and make me question it.... just like u now.
                from your photo I can tell Drum is still good , Blade is Good , I will try to rebuild that unit event I'm fail I will get a spare part for other unit.
                • copier tech
                  • 8174
                  These drums do not have a blade, just a charged cleaning brush.
