Generic drum for Advance 4545i?
  • campy
    • May 2012
    • 315
    I just bought one from a wholesaler with 73K on it and when I checked the drum counter says 333K, so the dealer probably swapped it before returning to the leasing company.. I really don't want to put a $400 drum in especially since I paid a premium for the low volume figuring I don't have to worry about a drum or fuser for some time. Has anyone used the Katun drum rebuild kit? They only rate it for 150K but that will get me about 2 years out of it.
  • GIUBOSS
    • 1436
    Re: Generic drum for Advance 4545i?
    I don't think you have much choice if you don't want to spend a lot and as far as I know Katun produces better than many other compatible consumable manufacturers.
    • mga
      Copier Technician
      • Dec 2010
      • 1393
      This is strange the machine done 73k drum done 333k you sure the machine total counter hasn't been changed as when you fit drum you have to reset drum counter in service mode
      Regards Mark
      • campy
        • May 2012
        • 315
        The drum was probably taken out by the returning dealer since it only had 73K on it and put in a drum that had 333K. The machine looks new and the other counters are in line with a machine with 73K.
        • mga
          Copier Technician
          • Dec 2010
          • 1393
          The drum on this model does not have a chip that means no matter what the life should be the same as the copier
          Regards Mark
          • Pete from Prescott
            • Feb 2012
            • 26
            Been using Katun since 1980s. Haven't for awhile , but their quality never was an issue.
            • campy
              • May 2012
              • 315
              We had many problems with them for Canon.
