Hello everyone,
I'm facing an issue on an iR2530i and it's giving me headache..
Some info on the printer :
(edit : idk what's wrong with the listing, everythings seems fine in edit mode)
After all this, I was thinking that maybe there was something wrong with the customer electricity as I was running out of idea
So i asked to swap copier with one working so I can check their's at workplace / testing the electricity thing at the same time... turns out it's not that
On the attached jpeg, you can see on the top part of it an original printout, and bellow it the copy of the copy of the copy
Note that the scanner unit is working just fine, scanned documents does not show poor quality
Any idea on what can cause such issue ?
- 256k copy
- Canon toner
- Changed in following order :
- 2772B00xxx - Drum
- FM3-9263 - Developping assembly
- Suggested by a colleague :
- FC9-0693 -Transfer Roller
- FC9-0693 - Registration Roller
- FM4-4981 - Hopper assembly
- FM3-9406 - Laser assembly
