iR2530i - Print quality really poor
  • Daemon
    • Sep 2020
    • 13
    [CQ] iR2530i - Print quality really poor
    Hello everyone,
    I'm facing an issue on an iR2530i and it's giving me headache..
    Some info on the printer :
    • 256k copy
    • Canon toner
    • Changed in following order :
    1. 2772B00xxx - Drum
    2. FM3-9263 - Developping assembly
    3. Suggested by a colleague :
      1. FC9-0693 -Transfer Roller
      2. FC9-0693 - Registration Roller
    4. FM4-4981 - Hopper assembly
    5. FM3-9406 - Laser assembly
    (edit : idk what's wrong with the listing, everythings seems fine in edit mode)
    After all this, I was thinking that maybe there was something wrong with the customer electricity as I was running out of idea
    So i asked to swap copier with one working so I can check their's at workplace / testing the electricity thing at the same time... turns out it's not that
    On the attached jpeg, you can see on the top part of it an original printout, and bellow it the copy of the copy of the copy
    Note that the scanner unit is working just fine, scanned documents does not show poor quality
    Any idea on what can cause such issue ?
    Re: iR2530i - Print quality really poor
    Have you cleaned the laser glass?
    • Daemon
      • Sep 2020
      • 13
      Yeah, I have cleaned it > ran some test > same issue > swaped it with a working one > new tests > still same issue
      • nochick
        • Jan 2012
        • 80
        It's seem you already change almost everything haha
        From your sample photo could be fixing element.[heat film only will do if u can find in your area]
        Goodluck
          Jam the machine, is it happening before the fuser or afterwards.
          • Daemon
            • Sep 2020
            • 13
            RESOLVED : iR2530i - Print quality really poor
            Resolved !
            If anyone encounter this : the culprit was the High Voltage PCB Assembly
