Dead Canon IRC 2380i only green power light ON, NO control panel operation
  • abdu
    • Apr 2021
    • 8
    Can't Print or Copy. This machine sounds like it warms up and is ready but there are no lights on except the green power light. so, it does not print or copy and the print button on the copier does not go green (its off). If you raise the adf, the scan lamp lights for moment like normal.
  • GIUBOSS
    • 1437
    Re: Dead Canon IRC 2380i only green power light ON, NO control panel operation
    most likely the main controller or the faulty ram
    • abdu
      • Apr 2021
      • 8
      Thanks, I will try to change RAM
      • abdu
        • Apr 2021
        • 8
        I cleaned the RAM and re-installed it it worked but it gave me the error
        E-000748-4000
        • GIUBOSS
          • 1437
          E-000748-4000
          Cause:
          Poor connection of peripheral cards or memory DIMMS.
          Corrupt System Software.
          Action
          Reseat all peripheral cards (UFR Board, Resolution Switching Board, USB I/F Board and the like) SDRAM & Boot Rom on the Main Controller PCB Assembly.
          Format HDD and reload System Software.
          • GIUBOSS
            • 1437
            Cause:
            Action
            Board Cleaning_Board Position-TP07 094.pdf
            • abdu
              • Apr 2021
              • 8
              Cause:
              Action
              I cleaned all connections and re-installed.
              All that remains is to format the hard drive
              Please provide me with the programs that I must copy after formatting
              • copier tech
                • 8195
                Why do you want to format the HDD?
                • abdu
                  • Apr 2021
                  • 8
                  Honestly, I do not know the reason .... But I took all the previous steps ...
                  Only (Format HDD and reload System Software) remains.
                  • copier tech
                    • 8195
                    If the HDD was the issue you would have an E602 error code not a blank screen.
                    However you were able to format the HDD & reload the firmware using the SST?
                    • abdu
                      • Apr 2021
                      • 8
                      Thanks for the quick response. I have a printer with the same model. I changed all cards and the problem is still the same error. so am Clear all errors By pressing the buttons * 28 * funcation ........ The result is same error E-000748-4000 ?????
                      • abdu
                        • Apr 2021
                        • 8
                        Thanks, everything is alright
                          so what fixed your problem?
                          asking for a friend.
                          • abdu
                            • Apr 2021
                            • 8
                            I have removed all the cards
                            I turned the machine on
                            I locked it down
                            I cleaned the motherboard and cards with alcohol
                            • copier tech
                              • 8195
                              "I locked it down" was the fix ............
