iRC5045 drum won't reset automatically
  • Toner Boy
    • Aug 2007
    • 364
    I manually cleared PT-DR-M but the LF counter for M still reads 0, should be 100?
    Installed 2 drums in an identical machine last week and both reset automatically upon install.
    Power was off, but main switch was still on - could this cause chip issue? Disabled AINR, , rebooted, reenabled AINR
    Concerned that the state and data of new drum is using old values still, M has weak solids
    Re: iRC5045 drum won't reset automatically
    are the genuine OEM drums?
    • Toner Boy
      • Aug 2007
      • 364
      Yep, fresh seal, old chip? firmware compatibility maybe
      • copier tech
        • 8136
        New drums on Canon the LF counter starts at 0% when they reach 100% that's end of life. (but you can usually get 150% without any quality issues.)
        LF Counter.pdf
        • mga
          Copier Technician
          • Dec 2010
          • 1393
          When you fit drum it goes back to 0 when on 100% that means life is up
          Regards Mark
          • Toner Boy
            • Aug 2007
            • 364
            RE: When you fit drum it goes back to 0 when on 100% that means life is up
            Thanks for clarifying, what threw me is that the Y drum is also reading 0 in the LF counter; and it's clearly been in the machine for a long time.
            This machine has been previously serviced, not by us...
            • Canuck
              Tech Specialist
              • 1713
              The new drum has a fuse that is opened when installed, resetting the life counter to "0". These machines measure drum film thickness to calculate drum usage(%)
