Canon iR ADV C5250 Black Drum Sensor
  • richmond
    • Feb 2021
    • 9
    Please I need help to resolve my Printer Canon iR ADV C5250, Everything seems to be okay with the printer although Auto color mismatch is not working.
    I have notice the Black Drum Sensor is not working. I need help to resolve this and I believe is the reason why Auto Color mismatch is not working.
    Any help to resolve this problem?
    Re: Canon iR ADV C5250 Black Drum Sensor
    [ATTACH=CONFIG]49033[/ATTACH]
    did you clean the belt sensors before running ACC?
      • 8163
      What makes you think the black drum sensor is not working? Do you have an error code?
      Check the drum is seated correctly.
      If the drum is not genuine Canon you will get colour mismatch issues.
        Print test print PG10, scan it and upload it here.
        • richmond
          • Feb 2021
          • 9
          Yes I've cleaned them very well...
          • richmond
            • Feb 2021
            • 9
            I have checked and the drum is seated well, I was only guessing about sensor not working.
            No error code.
              No error code.
              is it a genuine OEM K drum?
              what formal training have you had on copiers/printers?
              i see you are an IT tech....
              • mga
                Copier Technician
                • Dec 2010
                • 1393
                Go back to basics what's the parts life do a test page 10 if the colour are not solid you will get a colour registration problem.
                If test page is OK clean Id sensors and laser glass.
                Also you said everything is OK with printer so why are you doing a colour mismatch adjustment
                Regards Mark
                  • 8163
                  No error code.
                  You are 'Guessing'
                  And what about my last question is the drum genuine Canon?
                  • tech28
                    • Jun 2013
                    • 434
                    Check shutter?
                    • Canuck
                      Tech Specialist
                      • 1713
                      When it fails auto-color mismatch, it is failing setting up color registration. Itb wandering, patch readers dirty possibly...broken shutter(usually throws E020s though) Print a grid(test 6 I believe) and look at it with a loupe..probably see colors misaligned. Clean inside of itb and all its drive rolls and internal secondary roll. Might need to replace belt. I've had lasers cause this also..usually itb associated
