IRA C256i & IRA C256i 3rd generation
  • copier tech
    • 8172
    [Misc] IRA C256i & IRA C256i 3rd generation
    Hi all,
    Quick question what are the differences between these models please?
  • giogi
    Engineer senior
    • Jan 2016
    • 181
    Re: IRA C256i & IRA C256i 3rd generation
    Different type of connectors.
    Some electrical boards PCB different.
    On the touch screen there is the Timeline column on the right.
    Some strandard functions:
    - Web Browser
    - Encrypted Secure Print
    - Secure Watermark
    - Encrypted PDF+Device signature PDF
    SIEM / SYSLOG
    SECURE BOOT during the start up
    McAfee Embedded Control
    Different System Software (I & III edition)
    With the introduction of the 3 edition models, the service modes for changing the thresholds of the level of toner level.
    Previously, the service modes COPIER>OPTION>FNC-SW->T-DLV-X and COPIER>OPTION>DSPLY-SW->T-DLV-X were used to change the toner level.
    COPIER>OPTION>DSPLY-SW->T-LW-X) on a percentage that indicated that when the XX % of remaining quantity of toner, now with these new machines we go from a percentage to a number of days.
    "Knowledge is a source, but unfortunately ignorance is a sea."
    • copier tech
      • 8172
      - Web Browser
      - Secure Watermark
      SIEM / SYSLOG
      Thank you for this info much appreciated.
      I have a few C256i with failing ITB units after replacing them I tried to update the firmware as per the bulletin however I couldn't get this to load so was wondering of i'm trying to load the wrong type. On the counter print it does not say if the machine is a gen 3 etc it just shows the model as a C256i.
      Measure against lines caused by ITB.pdf
      • giogi
        Engineer senior
        • Jan 2016
        • 181
        For the III edition on the front door near the model is printed a symbol "III".
        the system of 256 is different from the system of 256 III ed.
        • copytech,mike
          CopyTech,MIKE
          • Jun 2014
          • 261
          [ATTACH]49154[/ATTACH]
          Transfer belts dont hold up very well on these desktop models. Its an expensive machine to maintain. Better charge about .04 cents per copy and .10 for color. Lost my ass selling this model a few times. Ive also seen the main board blow out after a few years. Its a junk model.
          • zoraldinho
            teacher-guide-expert-guru
            • Mar 2008
            • 5015
            Update via CDS.You can't miss.
            On this model i change itb many times in a short timeAlso main controller is not ok.
            • copytech,mike
              CopyTech,MIKE
              • Jun 2014
              • 261
              Its a terrible model. You would like the Konica Minolta c3350 alot better! 3rd Generation is alot of bullshit. Its the same darm machine. All they did was make a few changes to firmware. Its the same old C256if piece of junk.
