Canon C3530i
    Re: Canon C3530i
    Originally posted by copytech,mike
    you are not a technician. Thousands of innocent people are getting killed by guns and you are on here using an assault weapon as your prophie photo to intimidate people and promote your 10,000 political posts on a website that is supposed to be for copier tech help. Get the heck off this website. [ATTACH=CONFIG]49236[/ATTACH]
    aww poor little wimp you are intimidated by a cartoon pic? Are you a secret muslim? my pic is an AR15 muslims use AR-47/74 a way more powerful weapon.
    bet you (living in MD) haven't even HELD a firearm... guns don't kill people STUPID liberals with guns kill people...
    do you know rifles are used less frequently in shootings than pistols? My AR15 isn't even as powerful as my 40cal semiauto pistol
    hell more killings are committed by people using knives and hammers that firearms. So if you are going to talk about firearms make damn fucking sure you have the FACTS to back up your bullshit because
    My facts don't give a FUCK about your wimpy ass feelings.
    check out these facts about who gets killed more by cops.... FBI — Expanded Homicide Data Table 6
      Re: Canon C3530i
      It is a good thing that you are the owner. Otherwise I would be contacting your boss and informing him of your extremely bad attitude.
      • copytech,mike
        CopyTech,MIKE
        • Jun 2014
        • 261
        #48
        Re: Canon C3530i
        violation of forum rules:
        1. We reserve the right to remove offensive posts without notice and also reserve the right to ban anyone who willfully violates the forum rules
        9. Also while these rules cover most common situations, they cannot anticipate everything. Consequently we reserve the right to take any actions we deem appropriate to ensure these forums are not disrupted or abused in any way.
        4. We do not allow posts or links to sites that are pornographic in nature or violate Copytechnet community standards. The Copytechnet staff shall be the sole arbitrator of what does and what does not violate community standards.
        Im in no such violation.
          • 37556
          #49
          Re: Canon C3530i
          That will be for the admin to decide not you.
            Re: Canon C3530i
            Bullshit you need to READ the forum rules i mentioned clearly in violations.
            If you weren't so arrogant you'd notice it.
            • copytech,mike
              CopyTech,MIKE
              • Jun 2014
              • 261
              #51
              Re: Canon C3530i
              Originally posted by Canuck
              Imagerunner Advanced Colour C3530i? Switch black drum with yellow. Still there? Replace the black dev assembly., as "copier tech" suggested. A dirty laser path would lighten the image, not cause a semi-repetitive "spot-black" grey line. Itb cleaning failure would give a brownish waste toner coloured(process black/grey) line. A Test 10 would have been nice from service mode. As suggested, change the black dev
              Maybe blk dev unit yes but i went over it really well and it seems ok. Theres a wear line on my belt and outer trans roller.
              • copytech,mike
                CopyTech,MIKE
                • Jun 2014
                • 261
                #52
                Re: Canon C3530i
                Originally posted by mga
                Does it do it on test print page
                yep.
                • copytech,mike
                  CopyTech,MIKE
                  • Jun 2014
                  • 261
                  #53
                  Re: Canon C3530i
                  ​Anyway back on topic!
                  Check the k developer unit, I suspect from your print samples you have a build on the dev roller this would explain when you get this band when printing yellow only.
                  An ITB cleaning issue would produce thick often brown lines not a think band.
                  Maybe your right. I looked at the blk dev unit and the brush looks ok. I can go back and check it again. Any fix for it? Im running out of money on this thing. Only has 75k on it.
                  • copytech,mike
                    CopyTech,MIKE
                    • Jun 2014
                    • 261
                    #54
                    Re: Canon C3530i
                    Any way to fix the Dev high spot?
                    • copytech,mike
                      CopyTech,MIKE
                      • Jun 2014
                      • 261
                      #55
                      Re: Canon C3530i
                      Thanks. I agree. Blk dev unit. Yes, if i swich drums around its still there. I saw a slight high spot on the mag roller once but seemed to go away. Going back to check it again. Maybe i can shake it back and forth. Doctor blade is ok. That developer mix might not be even in the housing. Copier got moved while back agao. Maybe it got tilted. Gonna look for 1/2 wide high spot on roller. Dev unit rated at 240k. I hate to pay 400 for new unit.
                        • 37556
                        #56
                        Re: Canon C3530i
                        Replace the development unit with a new one from Canon.
                        • copytech,mike
                          CopyTech,MIKE
                          • Jun 2014
                          • 261
                          #57
                          Re: Canon C3530i
                          Based from what I have seen reading through this thread, when the admin gets time to review the reports on this thread copytechmike will be deleted from this website.
                          FYI, SEF and LEF stand for Short Edge Feed and Long Edge Feed. I learned that at the first instructor lead class I attended which was over 20 years ago. It help identify where marks on prints are in the direction of the feed or across the direction of the feed.
                          Dont think i will be deleted.
                            Re: Canon C3530i
                            you have been here since 2014...
                            1)you have spent more time here in the past three days than all the other time combined ...
                            2)you have raised more hell in those 3 days...
                            3)you have a ton of RED CARDS ....
                            4)you have been reported by more people in those three days than the majority of other people..
                            frankly it's not really looking that good for you
                              Re: Canon C3530i
                              5) you have argued/insulted 3 senior techs that are held in high regard here at CTN
                              • copytech,mike
                                CopyTech,MIKE
                                • Jun 2014
                                • 261
                                #60
                                Re: Canon C3530i
                                I think its looking real good for me. You have no power on here at all. Now be gone.
