Canon C3530i
    Re: Canon C3530i
    Originally posted by copytech,mike
    You were being very harsh and making smart remarks. I came on here for help and your talking about Genuine Canon parts. Also, you dont replace the transfer belt cleaning blade on this model. You replace the entire cleaning unit for about 30.00. Theres nothing to vaccum. I told you i replaced the blk drum and got the same result. That should tell you that the old drum was ok. Maybe the belt is badly worn and picking up some toner. In general the new cleaner unit comes primed. In most bigger models i prime the new blade using yellow toner. Reported me for saying asshole? Your pathetic Phil.
    violation of forum rules:
    1. We reserve the right to remove offensive posts without notice and also reserve the right to ban anyone who willfully violates the forum rules
    9. Also while these rules cover most common situations, they cannot anticipate everything. Consequently we reserve the right to take any actions we deem appropriate to ensure these forums are not disrupted or abused in any way.
    4. We do not allow posts or links to sites that are pornographic in nature or violate Copytechnet community standards. The Copytechnet staff shall be the sole arbitrator of what does and what does not violate community standards.
      Re: Canon C3530i
      As you wish.
      I will never try and help this guy again. we try to help by asking pertinent questions and I get cussed at... done with this sorry knowitall User.
      • copytech,mike
        CopyTech,MIKE
        • Jun 2014
        • 254
        #33
        Re: Canon C3530i
        You were the one acting like a know it all and making like i dont know anything. You were not nice to me. I quoted your name or your blackcat buddy by pure mistake and you guys were making smart remarks about it. You should re-evaluate yourself.
          Re: Canon C3530i
          awwww poor little baby....if you can't handle the heat stay the hell outta the kitchen.
          how old are you? 5?
          I standby all my remarks/suggestions ... I'm pretty sure you won't have to worry about me or BlackCat again....
          • copytech,mike
            CopyTech,MIKE
            • Jun 2014
            • 254
            #35
            Re: Canon C3530i
            how old are you? 5?
            Ok Master.
            • copytech,mike
              CopyTech,MIKE
              • Jun 2014
              • 254
              #36
              Re: Canon C3530i
              how old are you? 5?
              Im pretty sure i can get bye without you.
              • copytech,mike
                CopyTech,MIKE
                • Jun 2014
                • 254
                #37
                Re: Canon C3530i
                you quoted blackcat but you used my name?
                what are you with me on? that you don't know LEF or SEF? i would say SEF since you state there is the defect on the left hand side of the belt.
                was the cleaner unit BRAND NEW? or rebuild? did you make sure the blade in the cleaner was properly powdered? if a used belt cleaner did you vaccume it out?
                are you sure the rollers in the ITB are coming up properly and not dipping or not contaminated .
                please tell us they are using genuine OEM supplies!
                is the machine clean inside? laser lenses ?
                is the mark on the old drum unit?
                soo many things you haven't explained.
                A laser lens has nothing to do with a black line.
                  • 8103
                  #38
                  Re: Canon C3530i
                  ​Anyway back on topic!
                  Check the k developer unit, I suspect from your print samples you have a build on the dev roller this would explain when you get this band when printing yellow only.
                  An ITB cleaning issue would produce thick often brown lines not a think band.
                  • Canuck
                    Tech Specialist
                    • 1713
                    #39
                    Re: Canon C3530i
                    Imagerunner Advanced Colour C3530i? Switch black drum with yellow. Still there? Replace the black dev assembly., as "copier tech" suggested. A dirty laser path would lighten the image, not cause a semi-repetitive "spot-black" grey line. Itb cleaning failure would give a brownish waste toner coloured(process black/grey) line. A Test 10 would have been nice from service mode. As suggested, change the black dev
                      • 22934
                      #40
                      Re: Canon C3530i
                      From your sample:
                      C: 2%,
                      M: 3%
                      Y: 0%
                      K: 15%
                      Sounds like composite black to me.
                      • copytech,mike
                        CopyTech,MIKE
                        • Jun 2014
                        • 254
                        #41
                        Re: Canon C3530i
                        [QUOTE=Phil B.;1777835]violation of forum rules:
                          Re: Canon C3530i
                          Aneurysm. Thousands of innocent people are getting killed by guns and you are on here using an assault weapon as your prophie photo to intimidate people and promote your 10,000 political posts on a website that is supposed to be for copier tech help. Get the heck off this website. [ATTACH=CONFIG]49236[/ATTACH]
                          there are more people killed by CARS every year than by guns and that avatar is available thru CTN so go complain to Aneurysm because he is the owner and ONLY admin here.
                          it's not JUST for copier/printer help as you are well aware because you trolled me on the RANT & RAVES forums.
                          and posting 5-10 comments blasting two senior techs in a row is a little over the top.
                          self proclaiming you now RUN the canon threads doesn't mean shit until Aneurysm gives you that title. so go plead with his to see if you get that job.
                          you have a lower rating than me here so you get off this website...
                          you are really making an ass of yourself... go drink a beer.. smoke a joint .. or tug your babymaker... but chill the fuck out.
                          "you are not a technician " really so those thousand printed certs from all sorts of brands don't mean shit huh?
                            • 36857
                            #43
                            Re: Canon C3530i
                            wow that's really winning friends and influencing fellow techs.
                            Based from what I have seen reading through this thread, when the admin gets time to review the reports on this thread copytechmike will be deleted from this website.
                            FYI, SEF and LEF stand for Short Edge Feed and Long Edge Feed. I learned that at the first instructor lead class I attended which was over 20 years ago. It help identify where marks on prints are in the direction of the feed or across the direction of the feed.
                              • 36857
                              #44
                              Re: Canon C3530i
                              You Phil are arrogant and i have heard how you corrospond to newbies and you have no business on here and i don't care about your Rep score because it is 100% meeningless to me. I have been working on copiers and attending Factory training schools longer than you have been alive and i Stand by all of my statements about you. Now get off this webite. Do not make anymore post. And take your Blackcat Pal with you. You are not going to have any luck with your false report about me. I AM NOT ANY PORNOGRAPHIC VIOLATOR. IM A COPIER COMPANY OWNER. YOU ARE THE ONE WHO IS ABOUT TO GET REPORTED. I dont hide my face but you do hide your face. I AM MICHAEL GINGELL OF ADVANCED COPIER SOLUTIONS OF SILVER SPRING MARYLAND. NOW GET OFF THIS FORUM.[ATTACH=CONFIG]49229[/ATTACH]
                              It is a good thing that you are the owner. Otherwise I would be contacting your boss and informing him of your extremely bad attitude.
                                Re: Canon C3530i
                                go suck a big one little boi... I have every right to be on this forum... same as YOU for now.
