Canon C3530i
    Re: Canon C3530i
    Originally posted by copytech,mike
    Thanks Phil
    you don't have to explain the print/copy process to me I am well aware of it.
    but you STILL haven't answered LEF or SEF!
    DO YOU UNDERSTAND THAT TERMINOLOGY?
      • 22932
      #17
      Re: Canon C3530i
      I think you're missing the point. Transfer waste is always composite black ... sort of a cross between brown and purple. Even on single color images the transfer belt is used, and the transfer waste will still be composite black. Keep in mind that when doing single color images all the developer units are agitating, all the drums rotating, etc. So if there is a line on the black drum, or the black drum isn't cleaning, you'll still see that black line on the all yellow single color image. =^..^=
      • copytech,mike
        CopyTech,MIKE
        • Jun 2014
        • 254
        #18
        Re: Canon C3530i
        Originally posted by mga
        Does it do it on test print page
        yes it does.
        • copytech,mike
          CopyTech,MIKE
          • Jun 2014
          • 254
          #19
          Re: Canon C3530i
          Yes Phil im with you on that. I can tell you its not the blk drum. I put in a new 1 and same thing. Replaced the transfer cleaner unit. It has to be coming from the belt. My guess its a worn out belt. This model is nothing more than a desktop in my opinion and the transfer belt looks awful. Its pretty bad when your transfer belt is rated at less than 100k. I run a copy and then pull the belt unit and theres about a 3" portion of blk residue on the far left of belt near cleaner unit. I just didnt think the belt would be shot at only 75k.
          • copytech,mike
            CopyTech,MIKE
            • Jun 2014
            • 254
            #20
            Re: Canon C3530i
            No i dont. Im a little out of date. Im on my own since 2010. I dont get to attend copier schools anymore.
              Re: Canon C3530i
              you quoted blackcat but you used my name?
              what are you with me on? that you don't know LEF or SEF? i would say SEF since you state there is the defect on the left hand side of the belt.
              was the cleaner unit BRAND NEW? or rebuild? did you make sure the blade in the cleaner was properly powdered? if a used belt cleaner did you vaccume it out?
              are you sure the rollers in the ITB are coming up properly and not dipping or not contaminated .
              please tell us they are using genuine OEM supplies!
              is the machine clean inside? laser lenses ?
              is the mark on the old drum unit?
              soo many things you haven't explained.
                • 22932
                #22
                Re: Canon C3530i
                you quoted blackcat but you used my name? ...
                Lol. I noticed that too. =^..^=
                  Re: Canon C3530i
                  me thinks he is confused and getting very rattled. but HEY what do I know?
                  • copytech,mike
                    CopyTech,MIKE
                    • Jun 2014
                    • 254
                    #24
                    Re: Canon C3530i
                    I gave you more than enough info. I also gave a sample copy. And yes i used new Genuine Canon parts.
                    • copytech,mike
                      CopyTech,MIKE
                      • Jun 2014
                      • 254
                      #25
                      Re: Canon C3530i
                      Oh no sir, im not confused at all.
                        Re: Canon C3530i
                        I gave you more than enough info. I also gave a sample copy. And yes i used new Genuine Canon parts you asshole.
                        reported for language .. I didn't cuss at you .. no need to get nasty....
                        • copytech,mike
                          CopyTech,MIKE
                          • Jun 2014
                          • 254
                          #27
                          Re: Canon C3530i
                          You were being very harsh and making smart remarks. I came on here for help and your talking about Genuine Canon parts. Also, you dont replace the transfer belt cleaning blade on this model. You replace the entire cleaning unit for about 30.00. Theres nothing to vaccum. I told you i replaced the blk drum and got the same result. That should tell you that the old drum was ok. Maybe the belt is badly worn and picking up some toner. In general the new cleaner unit comes primed. In most bigger models i prime the new blade using yellow toner.
                            Re: Canon C3530i
                            Oh no sir, im not confused at all. I know your an asshole. Your also a lousy copy tech. A true fake.
                            keep it up Sir you are digging yourself a deeper hole... just because you OWN a company doesn't make you better than anyone else here.
                            I have great respect from all my customers and bosses. you need to get off of your high horse. Even Blackcat thinks you made a mistake quoting Him but using my name.
                            BTW you never answered my question I posed to you LEF or SEF. No wonder I have blocked you a long time ago. Look at your RED CARDS and Reputation points vs Mine.
                            I have worked on more brands than you have so there is that point also.
                            Hava great day...
                              Re: Canon C3530i
                              Shut your face.
                              wow that's really winning friends and influencing fellow techs.
                                • 22932
                                #30
                                Re: Canon C3530i
                                Shut your face.
                                As you wish.
