IRADv6055 jamming every time J0113
  • copier tech
    • 8142
    [Jamming] IRADv6055 jamming every time J0113
    Hi all,
    i'm a bit stuck with this jamming issue.
    Machine will work fine if doing single or double side copies however when I try to print say a counter page or print from a PC the machine will jam.
    Setting the machine to face up mode it will print the counter pages etc ok.
  • mga
    Copier Technician
    • Dec 2010
    • 1393
    Re: IRADv6055 jamming every time J0113
    Hi all,
    You have probably seen this
    Regards Mark
    • mga
      Copier Technician
      • Dec 2010
      • 1393
      Hi all,
      Or this
      Regards Mark
      • Hishamawada
        • 174
        hello my friend ,
        first of all is the paper jammed being damaged on Leading side ?
        as per your description there seems to be slipping or an obstacle in the turn unit towards exit paper path .
        kindly dismanlte the turn unit , clean all the rollers and their followers, replace the feeding rollers if they seem warn . clean all the bushings and i prefer to put few drops of oil on them . better replaced with the new ball bearing as mentioned in the pdf above.
        the turn unit body if there is any rust on them from the inside better smoothen it with a sand paper .
        you can also check the things listed in the photos .
        Sent from my SM-G610F using Tapatalk
        • copytech,mike
          CopyTech,MIKE
          • Jun 2014
          • 261
          Originally posted by Hishamawada
          hello my friend ,
          Never had much luck by adding an extra wrap. Printing from PC shouldnt matter. Sounds like its intermitent and fooling you. Check any cluches that my be involved.
          • copytech,mike
            CopyTech,MIKE
            • Jun 2014
            • 261
            hello my friend ,
            Bad sensor maybe? Try new one for about 6.95 or so. Worth a try.
            • Hishamawada
              • 174
              my friend there is no clutches related to this issue .
              Replacing parts isnt my first choice when I try to fix any problem .
              So trying to adjust the spring tension sometimes fixes the issue .
              • copier tech
                • 8142
                Thanks for the info, I believe the issue maybe with the Delivery reverse drive assembly, next time i'm doing a PM will order this part.
                • copytech,mike
                  CopyTech,MIKE
                  • Jun 2014
                  • 261
                  No cluch involved with pushing paper thru the machine? Theres always a cluch involved somewhere.
                  • Canuck
                    Tech Specialist
                    • 1713
                    Because they use stepper motors now instead of clutches, when the bushings in the delivery assembly get gummed up, the load causes the stepper motor for the delivery drive to stall(old DC motors never stalled..ran all the time, Dcon turned clutches on and off for operation usually). As mentioned, do the mod and get rid of the bushings in the delivery assembly. Bearings will take the load off and you probably won't need to replace the delivery drive assembly. It sucks changing the delivery drive..big time..I've done a few
                    • copier tech
                      • 8142
                      Great explanation this makes perfect sense.
                      So, as a quick test applying spray oil to these bushing should, in theory, temporarily resolve this issue?
                      • Hishamawada
                        • 174
                        i prefer you clean the whole turn unit as i mentioned above then put some oil
                        • Canuck
                          Tech Specialist
                          • 1713
                          Yes oiling will loosen them up enough to verify issue but these are Oilite bushings are are not meant to be oiled. If you oil them, it mixes with paper fibers,toner etc and seize again. Oiling gets rid of the symptoms..bearings will eliminate the problem. 62xx/82xx come with bearings already in them
                          • copytech,mike
                            CopyTech,MIKE
                            • Jun 2014
                            • 261
                            Makes sense. Fewer clutches is a good thing.
                            • copytech,mike
                              CopyTech,MIKE
                              • Jun 2014
                              • 261
                              Ive had good luck with a drop of tri-flow on those oilite bushings and i normally try to take things apart if i can to clean the shaft and bushings ect. I will keep your info in mind. Drive units getting gummed up.
