Canon iR Advance C5540i error 602-0801
  • Tim C
    • 167
    I have this problem with a Canon C5540i.. Error code 602-0801 occurred
    I went to the customers office to clear it and I selected the option for CHK Hard Drive
    It said this will take 100 minutes, Ok I left the machine and called them back 2 hours later and
    they said it was stuck on 15 minutes for the last 1/2 hour.. So i was thinking Hard Drive Failure.
    I have a working C5550i machine in our office that I pulled the Hard Drive from and Installed into their
    machine. So it went into the 100 minute thing again , so I left hoping this would recover by the morning
    So after all of this, I read in the Service Bulletin that you should not swap Hard drives. I have not checked on the machine this morning yet
    Any Suggestions for a fix ?
  • bobburnsreb
    • Mar 2015
    • 233
    Re: Canon iR Advance C5540i error 602-0801
    Gen 3 devices (all editions - C55xx, 45xx...etc...), when needing to format the HDD, after the format is complete just cycle power. The System Software backup resides on the Flash PCB. Just my suggestion!
    • copier tech
      • 8172
      Quickest way fit the old or new a HDD then boot up off a USB firmware pen created with the SST then format the HDD & reload the SSW.
      • alex@wocltd.com
        • 430
        you cant just pull hdd from the later machines(like you could on the earlier ones) - for each machine you will need to format and install s/s........
        • Tim C
          • 167
          Ended up reformatting the HD and reinstalling the System software and its working now, thanks
          • muhammadreza
            Lerner
            • Aug 2012
            • 39
            How i find HD format firmware?
            • bobburnsreb
              • Mar 2015
              • 233
              The format file comes with the system software when you download from Canon.
              • techandtrader
                • Jun 2016
                • 335
                C5500 Drives are married to the machine. Must replace with a new one when needed.
                I have used Canon Imagerunner parts for sale. Most are floor model Color and / Advances Imagerunner with some 3025 3235 parts. Several intact machines being parted.
                • skibum
                  Independent Service Tech
                  • 234
                  Can you just reformat and then power cycle on and the original system software will reload onto the hdd from the flash pcb which resides on the IRC5550i??
                  • ADV COPIER
                    Pemain
                    • Nov 2022
                    • 257
                    yes you can
                    Let's Drink our Coffee
                    WhatsApp +62895325228383
