Import/Export address book via USB
    • 8131
    [Misc] Import/Export address book via USB
    Hi all,
    As the title says I have an few C35xx coming out & a few C55xx going in so would save me time if I can use a USB pen to import the address book & network settings if possible via pen drive or is the only option via the RUI ?
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5007
    Re: Import/Export address book via USB
    (Settings/Registration) <Management Settings> <Data Management> <Import/Export>
    You can export all the settings information into a USB memory device.
    I haven't tried this method yet
    • fchu5959
      Field Engineer
      • Jun 2010
      • 100
      Hi all,
      yes,you can import/export all or selected settings including address book and service mode( with a password) via a usb key as suggested Zoraldhino.
      You can do it among all GEN 3 machines;either via RUI or on the machine itself.This will generate a DCM file.
      This method is very handy and time saving upon installation;so,always keep at hand the DCM files of different models on a usb key;
      On these GEN 3 machines, make it a good habit of generating a DCM file before clearing DCON/RCON/Mncon.This can help you saving a lot of trouble and time
      when you have an issue..
      Take care.
      • giogi
        Engineer senior
        • Jan 2016
        • 182
        important thing:
        to import the service modes into the same DCM file, remember to set first
        COPIER>OPTION>USER>SMD-EXPT>1>OK
        then the procedure is correct as indicated by others
        "Knowledge is a source, but unfortunately ignorance is a sea."
          • 8131
          Thanks for info guys, will give this a try.
          • mga
            Copier Technician
            • Dec 2010
            • 1393
            I use this method
            Regards Mark
            • Canuck
              Tech Specialist
              • 1713
              I use it all the time...it's so convenient
