Feeding test for DADF-K1
  • Michael
    • 158
    Hello is there an option or service command to test feeding without making copies ? thanks for information Michael
    My profile is not working at the moment. The profile you see is not mine. Board redirects to a wrong userprofile. So you CAN´T REACH ME over the profile via SEND PRIVATE MESSAGE and even not over regular Email too
    You only can contact me if you click my name on a post and select PRIVATE MESSAGE straight from there.
  • giogi
    Engineer senior
    • Jan 2016
    • 181
    Re: Feeding test for DADF-K1
    maybe
    FEEDER>FUNCTION>FEED-ON>OK
    "Knowledge is a source, but unfortunately ignorance is a sea."
    • copier tech
      • 8144
      I use the DF cleaning option in additional functions > maintenance > DF cleaning.
      • Michael
        • 158
        exactly what i need thanks.
        Michael
        • 20 year tech
          • May 2014
          • 577
          you can also use the job build feature on Canon machines to test the doc feed. just cancel the job when done testing.
          • Venom
            Technical/IT Support
            • Nov 2009
            • 765
            This is my go to test!
            IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
