NP 6035
  • tcypy1961
    • 773
    NP 6035
    I'm rebuilding the fuser unit on this copier never serviced one of these copiers before. I removed the press roller by removing the screws on the pressure springs. I'm not sure how tight the pressure between the two rollers was so when I put it back together am I going to have to use trial and error to see if I have adequate pressure? I can somewhat remember about where the bracket with the tension spring was in relation to the frame. Any help will be greatfully accepted.
  • logonjim
    • 136
    np6035
    Sincere sympathy to you but thats not the way to over haul the fuser you should only access the pressure roller when you remove the top roller. You will prob have fixing problems but sure keep adjusting the tension on the pressure roller till it does not rub off
    • zaza
      MECANOGRAPHE
      • Mar 2008
      • 1095
      try this....
      hi friend try for this solution ..
      Originally posted by tcypy1961
      I'm rebuilding the fuser unit on this copier never serviced one of these copiers before. I removed the press roller by removing the screws on the pressure springs. I'm not sure how tight the pressure between the two rollers was so when I put it back together am I going to have to use trial and error to see if I have adequate pressure? I can somewhat remember about where the bracket with the tension spring was in relation to the frame. Any help will be grea [IMG]file:///C:/DOCUME%7E1/MECANO%7E1/LOCALS%7E1/Temp/msohtml1/01/clip_image002.jpg[/IMG]tfully accepted.
      BEST TECHNICIAN . NICE PEOPLE .
      • copymon
        • 39
        This should help. Never a need to remove the pressure spring screws, UFR must be removed to get the LFR out.
        • zaza
          MECANOGRAPHE
          • Mar 2008
          • 1095
          try this....
          I'm rebuilding the fuser unit on this copier never serviced one of these copiers before. I removed the press roller by removing the screws on the pressure springs. I'm not sure how tight the pressure between the two rollers was so when I put it back together am I going to have to use trial and error to see if I have adequate pressure? I can somewhat remember about where the bracket with the tension spring was in relation to the frame. Any help will be y accepted.
          hi friend l have service manuals for this copier if he can healpeing ..sand me your mail ...
            • 23009
            I haven't done a NIPP width adjustment in ages! Most fusers just don't give you the adjustment any more.
            If I have to move those screws I always measure the compressed length of the spring (this is just fuzzy memory, but I'm remembering 22mm). This should get you close. Now, key the front door interlock. When the machine is warmed up, run a letter sized sky shot. When the paper is 1/3 of the way into the fuser remove the interlock to jam the machine. Then wait ~15 seconds before rolling out the jammed copy.
            Now measure the glossy portion of the copy that was between the rollers. You're aiming for 5.5mm at both ends. The center should vary no more than +/- 0.5mm. If you don't want to look like a greenhorn, don't handle the unfused portion of the page. It will get toner all over your hands.
            Adjust the fuser pressure screws, then repeat until you get it perfect. =^..^=
