C5535 slow boot up
  • repeatcopiers
    • Sep 2008
    • 591
    C5535 slow boot up
    I have a C5535 that takes about 4 minutes to come to ready. I wanted to update the system software with a flash drive but when I power on while pressing 2 and 8 nothing happens, just a status bar about 1/4 way and no further progress. I can perform the diagnosis by pressing 2 and 4 and it comes back OK. I have changed the Main 1 but no change, also tried new HDD but can't flash it. Any ideas?
  • copier tech
    • 8172
    I would say the HDD is failing.
    Hold down keys 2&8 while powering on.
    • ADV COPIER
      Pemain
      • Nov 2022
      • 257
      Change the hdd
      Let's Drink our Coffee
      WhatsApp +62895325228383
      • repeatcopiers
        • Sep 2008
        • 591
        Originally posted by ADV COPIER
        Change the hdd
        When we put a new hdd in and hold down the 2 and 8 and power on, nothing happens, it never goes into format screen, only has a white status bar that never goes further than about an inch long.
        • repeatcopiers
          • Sep 2008
          • 591
          When we try that, it never goes into format screen, only shows about an inch long white status bar but never goes further than that so we can't format the hdd and load software from flash.
          • bobburnsreb
            • Mar 2015
            • 233
            I would start fresh with a new USB stick.
            Hard Drive Format (2).pdf
            • repeatcopiers
              • Sep 2008
              • 591
              [ATTACH]n1570384[/ATTACH]
              I saw your recent post about how to do this, so I did try that method but unfortunately it never gets to an entry screen when powering up. I hold the 2 and 8 turn power on like always but all I get is about an inch long white status bar. I even tried to do it from the service mode, going into Download mode from COPIER>FUNCTION>SYSTEM>DOWNLOAD and same inch long progress bar that never goes into format screen. Everything else about the copier seems to work, it is just very slow to come to ready. Every time it sits on the Checking Data, do not turn off main power screen for about 4 minutes. I don't know of any other way to get a new hard drive on it.
              • bobburnsreb
                • Mar 2015
                • 233
                If you start the machine without the Flash PCB (Board on Main Controller with the black chip and white sticker on it), does it give an E748-2010? If so, then you may need a Flash PCB and if not, then a Main Controller issue.
                I have left the progress bar overnight and came back in the morning to a ready state.
                • repeatcopiers
                  • Sep 2008
                  • 591
                  It gave me the E748 when started it without the Flash PCB. Is that the PCB that you have to get from Canon and have it registered for this copier or is it easier to get than that?
                  • bobburnsreb
                    • Mar 2015
                    • 233
                    Yes, special processing thru Canon.
