C5240, "printer malfunction"
  • Oystercopy
    • Oct 2009
    • 623
    hey guys.. totally unfamiliar with this machine. I haven't gone there yet, but I don't see any other message on the panel, from the picture the customer sent me.
    Any ideas?
    Thanks in advance!
    OC
  • ADV COPIER
    Pemain
    • Nov 2022
    • 256
    Share picture error
    Let's Drink our Coffee
    WhatsApp +62895325228383
    • Saturn
      • Nov 2023
      • 171
      Go to the copy mode, the error code is shown there E0000xxx-xxxx.
      I don't care about who your father is, as long as I'm fishing here, you won't walk on water.
      • Oystercopy
        • Oct 2009
        • 623
        The error is E75-0003
        • bobburnsreb
          • Mar 2015
          • 233
          Probably the worst code you can get. The transfer belt is not centered. Good luck in your fight.
          • Oystercopy
            • Oct 2009
            • 623
            Thanks for all the help guys! I probably wouldn't mess with trying to save the belt, I would just offer to replace the whole thing.
            OC
            • copier tech
              • 8163
              If you have the service manual, take the belt off, clean the large rubber drive roller & refit the belt.
              This will get the device up & running.
              • Oystercopy
                • Oct 2009
                • 623
                Just in case the customer did want to replace the belt, is there some kind of reset procedure for the error code that I have to do, or will the machine do it itself when rebooted?
                OC
                • bobburnsreb
                  • Mar 2015
                  • 233
                  If you have never done it before you will need the service manual. Send me an email address (PM) and I may be able to help you with that.
                  • copier tech
                    • 8163
                    OC
                    No reset needed, one you refit the belt & set it in the correct position. Refer to the service manual (attached below)
                    https://mega.nz/file/oJ9jlRTA#WTckyJ...JMLZ0Oi_xxcgE0
                    There was also a firmware update for this issue.
                    www.printerfirmware.co.uk
