C5235 need cleaning
  • carlsson
    • Apr 2021
    • 35
    [Misc] C5235 need cleaning
    My C5235 needs cleaning, and I will do a thorough cleaning when i get the time. Before that happens, is there an easy way to get rid of these marks?
    It only happens when I print double sided prints.
    Tia,
    /andreas
  • doktor
    • 214
    Re: C5235 need cleaning
    Drum are sucks
    • carlsson
      • Apr 2021
      • 35
      Originally posted by doktor
      Drum are sucks
      Thanks for the reply.
      If that's the case, wouldn't it be the same errors when printing single sided pages?
      • Hishamawada
        • 174
        They are drum unit issues.
        You can try swapping the drums with another color and check if the lines appear with different colors .
        Sent from my SM-G610F using Tapatalk
        • carlsson
          • Apr 2021
          • 35
          You are probably right guys. I have ordered 4 new drum rolls and cleaner blades. In the meanwhile, I'll pick them out and see if a little cleaning can help. If I'm not mistaken I did that with a printer 15 years ago and it helped, a little at least.
          Thanks for your answers!
          • copier tech
            • 8172
            You can't clean Canon drums, especially when they're worn out like yours clearly are.
            If you want the machine to be reliable fit a set of genuine Canon drum units not the rebuild kits.
            • Hishamawada
              • 174
              The compatible parts are always a waste of money , there lifetime is much less the genuine.
              If you want the rebuild it , you should also change the charging roller. Bad rollers will damage the drum soon and cause bad quality printouts
              • carlsson
                • Apr 2021
                • 35
                Thanks for all your input.
                Unfortunately I have already paid for it and they should be on their way... 😝
                These: 4 pcs. OPC DRUM ONLY IR C5240 C5235 C5035 C5030 C5045 C5051 GPR-31 GPR-30 GPR30 13803115659 | eBay
                It's the same price for four drum rolls as one complete drum set, at least from here in Sweden. Any better choices?
                Talking about spare parts; I have good experience from Katun, any opinions?
                • Hishamawada
                  • 174
                  Since you have already ordered them , its fine . Hope they will last long enough .
                  Genuine drums last around 120K sometimes more . For Compatible if your lucky they will last 50k . Not stating the quality drop in your prints .
                  It all depends on your type of work .
                  As i mentioned before , if you can get charging rollers would be much better.
                  Best of luck
                    Best of luck
                    As long as charge rlr isn't physically damaged.. try cleaning w/ NuFinish works great.. nay have to apply and buff off several times.
                    • dekoster
                      • Aug 2012
                      • 84
                      try to clean the transfer scraper and the transfer roller
                      • ReproKev
                        • 273
                        The pic looks like ITB cleaning blade to me.
