Canon iRADV 8585 error code E197-0181
  • Blues977
    • Jun 2024
    • 15
    Hi Good Day guys,
    I have a unit iRADV 8585 II with error code E 197-0181. Check on the error code the symptom is DC Controller.
    Anyone have face this error code ?
    Is the DC Controller machine version I and II same with machine version III ?
    Thank you in advance if you guys can advice me what to check on this problem
  • Saturn
    • Nov 2023
    • 171
    Originally posted by Blues977
    Hi Good Day guys,
    Gen I and Gen II is the same DC Controller, Gen III is different.
    I don't care about who your father is, as long as I'm fishing here, you won't walk on water.
    • papafred
      • Jun 2019
      • 11
      Check for paper in the electrical connectors behind the main drawer.
      • bobburnsreb
        • Mar 2015
        • 233
        Is there any other error code listed in Service Mode?
        If no other error codes, backup the DC controller then do a DC con clear.
        Reboot and see if the E197-0181 returns. If the code returns, do the restore of DC con.
        Possible issue with the dc controller.
        Check connections on the DC controller before replacing.
        I have had paper in the fuser connector as papafred said.
        • Blues977
          • Jun 2024
          • 15
          Good day guys,
          Thank you guys for the suggestion given.
          Anyway today I have check and try all the suggestion given by you guys still same error code after reboot the machine.
          Even I try clear the MN Con still the same. Is it possible to format the HDD and re-install back the firmware will fix the problem ?
          I not dare to try to swap the DC controller P.C.B from a working condition machine to this error code machine to confirm is DC Controller
          P.C.B problem. Any other method to recover this DC controller ?
          Thanks in advance again
          • Blues977
            • Jun 2024
            • 15
            Good day every one,
            After a month finally this unit with error code E197-0181 solved. Is due to human error by a junior engineer. He took a version 3 DC con p.c.b fix
            to a version 1 iRADV8585 machine and update the DC version that cause the error code.
            Remedy : Took the DC con p.c.b which error code fix back to version 3 iRADV8585 machine and overwrite the DC Con version to version 3 firmware.
