iR Adv 4525i hard drive
  • kuby
    • Oct 2007
    • 1396
    Anyone have a good hard drive for a ADV 4525i with the system software loaded on it that they might want to sell? Tech is having issues with one that he cant get the software to load.
  • copier tech
    • 8131
    I guess this is a duplicate post but we can supply a new HDD & firmware should you require this.
    www.printerfirmware.co.uk
    • bobburnsreb
      • Mar 2015
      • 230
      canon c3530i hard disk
      Started by aliburotic, 05-31-2024, 11:07 AM
      in Canon
      I would boot up in 2+4 mode and let it run box checker. Sometimes you get lucky and it will move the bad sectors and repair the HDD. If your having trouble with loading firmware check out the post above for format and firmware install. Go all the way to the bottom for the Canon Knowledge Base Article.
      Good Luck!
