Canon ImageRunner Advance C7570i III
  • Eddie100
    • Sep 2021
    • 3
    I have a canon C7570i III with an error code E000029-1000. I did a hard reset on the unit and after the reboot that came up. Any advise would be greatly appreciated.
  • copier tech
    • 8174
    Re: Canon ImageRunner Advance C7570i III
    Why did you perform a 'hard reset?' It sounds like the patch sensor is dirty, clean it.
    • Code: E029-1000-05
    • Description:Patch Sensor error
    • Causes:The Patch Sensor detected correction error of the light intensity value determined at initialization.
    • Remedy:[Related parts] R1.00 - Harness between the Multi Driver PCB (UN97/J1353) and the Patch Sensor (PS21/J7412) - Patch Sensor (PS21) - Multi Driver PCB (UN97) [Remedy] Perform the following in the order while checking whether the error is cleared. 1. If the sensor surface of the Patch Sensor is soiled, clean it with a cloth tightly wrung out of water. 2. Check/replace the related harness/cable, connector and parts. 3 Update system software
    • dekoster
      • Aug 2012
      • 84
      enter the standard values that are in the front door
      in the service model
      then switch the device off and on again
      Don't forget to delete the error code
      • Eddie100
        • Sep 2021
        • 3
          You need a manual.
          Request one in 'Manual Request' forum.
          • Eddie100
            • Sep 2021
            • 3
            You are a life saver. That was the issue. Thank you so much! God bless
