C2880i Color Displace Help
  • chrineuh
    • Sep 2021
    • 10
    Hello,
    I have bougth an used canon IR C2880i, i had a lot of problems with the toner dens but that problem i have fixet by the HV PCB thare was an bad contact to the ITB.
    But now i have an problem with the Colors they are not perfectli alined.
    (If i print out the in Service mode NR 6)
    i can see all the 4 colors but they are not at the rigth pos. , but the fault is not over the hole page only at the half of the Page witch comes out at the front of the printer.
    the other half ist much better alinement.
    I have try to ajust the IMG_REG but if the bad half ist ok than the other half ist bad.
    (i have checkt the LASER FSLUT vlues with the label in the printer) the are all rigth.
    I hope you can help mee
  • copier tech
    • 8138
    Re: C2880i Color Displace Help
    Originally posted by chrineuh
    Hello,
    Try a DC-CON CLR then run auto gradation adjust.
    • chrineuh
      • Sep 2021
      • 10
      Hello
      Thanks it is much better but not perfekt... but now the displacement of the colors it the same on the hole page
      dose someone have the test patterns for correcting that?
      i cant poste the sceenshot but an example is in servicemanual on page 505.
      CANON COLOR IR C3480 SERVICE MANUAL Pdf Download | ManualsLib
      thanks
      • copier tech
        • 8138
        Hello
        thanks
        What firmware version is the copier on ?
        • chrineuh
          • Sep 2021
          • 10
          I Hope that is what you need
          2021-09-12 20_56_41-Remote UI _Infos zur Einheit _ _ iR C2880 _ iR C2880.png
          • chrineuh
            • Sep 2021
            • 10
            Do you think its about the frimware?
            I have an new firmware from printcopy but i dont know how the Update works.
            I have the USB verson of the firmware, but the files dosnt look like that they are rigth.
            • copier tech
              • 8138
              Yes always worth trying firmware first.
              • chrineuh
                • Sep 2021
                • 10
                The problem is i don't konw how to falsh.
                the firmwar what i have looks like this:
                2021-09-13 14_08_25-USB_iRC3380_v97.01.01.zip (Nicht lizenzierte Testversion).jpg2021-09-13 14_08_46-USB_iRC3380_v97.01.01.zip (Nicht lizenzierte Testversion).jpg
                And the name of it is C 3380
                My printer is the C2880, but on the service manual are the C2880 and the 3380.
                Do you have the newest version ? and give me an Manual to make this?
                • copier tech
                  • 8138
                  [ATTACH=CONFIG]50127[/ATTACH][ATTACH=CONFIG]50128[/ATTACH]
                  Yes there are a few models in the series.
                  We can provide you with the latest firmware & service manual.
                  • chrineuh
                    • Sep 2021
                    • 10
                    Hello,
                    and what dose that cost to me?
                    • fchu5959
                      Field Engineer
                      • Jun 2010
                      • 100
                      Hi,
                      I suggest you clean the photo sensors located on the ITB frame;at the same time have a look at the drums state and the ITB cleaning blade.Replace if necessary.
                      I hope these tips will help you resolve the issue.
                      Take care.
                      • copier tech
                        • 8138
                        Hello,
                        We have the pricing on the website. You just need our 1x machine package.
                        • ernesto
                          • Oct 2011
                          • 430
                          Hello,
                          i cleaned the sensors int he process unit but it did not work and I EXCHANGED the process unit with other machine and now both of them are working ...............???????????????????????????
                          • copier tech
                            • 8138
                            Yes if you have another machine to borrow parts from that would be a great help.
                            • chrineuh
                              • Sep 2021
                              • 10
                              Hello,
                              I have found this:
                              In the text they mean i can do :
                              1) Perform the service mode > service chart print > service chart print 8.
                              But if I print in Service mode PG type 8 the image dose not look like in pic 2.
                              Dose someone know how i can print this out ( with that chart i can easy ajust the offset of the colors)
                              On the next page is a calculation to get the rigth offset values.
                              The manual is there Canon iR C2880 series Manuals | ManualsLib
                              and it is on page 504
