Canon C 7270 E0-77 ERROR
  • copytech,mike
    CopyTech,MIKE
    • Jun 2014
    • 200
    Replaced sec trans roller sensor. Cant figure out how to get to the motor in back. Dont think its a bad motor or connector on motor broken? Nobody has seen this problem yet. Need help.
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 4955
    Re: Canon C 7270 E0-77 ERROR
    Usually LEVER on the itb did not lock properly.Also HVT under sec. roller can be messed up with toner.(PS22)
    Practice makes perfect
    If you want something done right, you have to do it yourself
    • Hishamawada
      • 174
      Hi ,
      You can check the paper pickup driver pcb FM0-0741 and 2nd transfer drive assembly FM3-4972.
      Sent from my MAR-LX1A using Tapatalk
