Canon C 7270 E0-77 ERROR
  • copytech,mike
    CopyTech,MIKE
    • Jun 2014
    • 261
    Replaced sec trans roller sensor. Cant figure out how to get to the motor in back. Dont think its a bad motor or connector on motor broken? Nobody has seen this problem yet. Need help.
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5007
    Re: Canon C 7270 E0-77 ERROR
    Usually LEVER on the itb did not lock properly.Also HVT under sec. roller can be messed up with toner.(PS22)
    • Hishamawada
      • 174
      Hi ,
      You can check the paper pickup driver pcb FM0-0741 and 2nd transfer drive assembly FM3-4972.
      Sent from my MAR-LX1A using Tapatalk
