CANON C5250 scans problem
  • wcanonw
    • Aug 2014
    • 404
    Hello, good afternoon, I have a problem with a Canon C5240 printer. When I scan through the DADF, for example, I put in 20 sheets, all the papers go through normally, but it only scans 19 sheets on the machine.
  • copier tech
    • 8184
    Are you saying you have an issue with scan to email ?
    I would start by updating the firmware & check that the email file size is set to maximum.
    www.printerfirmware.co.uk
    • wcanonw
      • Aug 2014
      • 404
      Hello, the scan is smb from printer to computer (scan to folder). I put 20 sheets in the ADF and only 19 sheets are scanned, when I check the folder where the scan arrived, only 19 scanned pages appear.
      • copier tech
        • 8184
        IS the skipped page blank ?
        What if you scan say 50 pages, how many arrive in the folder ?
        • Brian8506
          • 1665
          If it says only 19 scanned, you're probably getting a double feed somewhere in the scan
          • wcanonw
            • Aug 2014
            • 404
            For example, if I send more sheets, at the end there would always be a scanned sheet missing. When I look at how the sheets come out, I see that they come out normally. I thought that suddenly it was pulling two sheets stuck together, but not all the sheets come out separately. I have not yet tried to perform maintenance on the dadf or update the firmware.
