Canon IPF 770 Plotter Hardware Error 03130031-2F1F
  • Hoosierdaddy
    • Oct 2016
    • 182
    [Error Code] Canon IPF 770 Plotter Hardware Error 03130031-2F1F
    From what I have read does this mean the Purge Unit is Defective? I also noticed A lot of Air in the ink lines. If this is the Purge Unit could someone get me the part number?
    Thanks in advance!
    Hoosierdaddy
    • 22994
    Re: Canon IPF 770 Plotter Hardware Error 03130031-2F1F
    It's the same purge unit used on all the iPFs: 650, 655, 680, 685, 750, 755, 760, 765, 770, 780, 785
    Originally QM3-5988-000 ... updated many times to currently QM4-3670-020.
    If you turn the motor manually, you should be able to watch it work mechanically ... pump in one direction, capping assembly in the other. When that ink starts hardening up into a rock the gears will break ... you'll hear the crunching.
    Keep in mind that this may be just the first of a string of expensive issues. You can expect to need a printhead, at minimum. It probably hasn't been properly capped in a while. =^..^=
    • Hoosierdaddy
      • Oct 2016
      • 182
      Does the air in the line point to anything? Or does the Purge Unit and the Printhead cause that issue?
        • 22994
        That's further down that road, after you solve the first issue(s). =^..^=
