iR400 head position short
  • nochick
    • Jan 2012
    • 80
    [CQ] iR400 head position short
    there's 1 of my ir400 that head position short about 1.2 CM. from orginal and when i print meter out it's the same
    I try to adjust in service mode but it's not help much it , I reduce shorten to 0.7 Cm. but it's not enough
    please help
    Where should i look?
    paper try is normal
    Is it Regis position wrong?
  • Brian8506
    • 1667
    Could be registration clutch. Also there is a black pressure clip with a pressure spring on either side of the reg roller to apply pressure. These can break.
    • nochick
      • Jan 2012
      • 80
      Thank you Brian8506
