Need parts or part #s for IR C3380i DADF pad and feed clutch spring
  • mjunkaged
    • 384
    Got a customer with a pad so worn it's got a 1/4" divot worn into it. Feed-in torsion clutch spring is broken in two ( I think) and it will turn backwards to lift pickup roller but won't turn forward to feed-in paper. Rollers look okay still, I'm guessing they won't need replacing but if you've dealt with this problem before I'm all eyes!! TIA.
  • mjunkaged
    • 384
    Disregard, found a feeder and urged the customer to not waste money on the old turd.
    • copier tech
      • 8156
      Great machine back in the day! I bet some veteran techs on here have the DF parts needed
      • nicknt82
        • Nov 2011
        • 155
        This Separate pad can use mutual with old Canon copier machine as R 3570, iR 4570, iR 3530, iR 4530, iR 2230, iR 2270, iR 2830, iR 2870, iR 3025, iR 3030, iR 3035, iR 3045, iR C2880, iR C2880i, iR C3380, iR C3380i, iR C2380i, iR C2550, iR C2550i, iR C3080, iR C3080i, iR C3480, iR C3480i, iR C3580, iR C3580i
        • techandtrader
          • Jun 2016
          • 333
          I have several of these pads I need to sell. Please contact if you need. I think they are extinct elsewhere!!!!!
          I have used Canon Imagerunner parts for sale. Most are floor model Color and / Advances Imagerunner with some 3025 3235 parts. Several intact machines being parted.
          • mjunkaged
            • 384
            Wish you saw this post when I posted it - the customer didn't want to fix it due to there only being an entire used feeder unit available at the time. But thanks anyway! ALSO needed the torsion spring it was broken in half.
