Canon advance 4051 fusing problem
  • Uniquer
    • Feb 2022
    • 30
    The machine was working normally but i needed ro replace fusing film due to some spots on it. After that the problem appeared.
    the first 4 or 5 pages are good then the toner not fixed at all pages afterwards without popping up any errors. Any ideas ? Thank you
    i uploaded the image with the fault
    This gallery has 1 photos.
  • bobburnsreb
    • Mar 2015
    • 233
    Part Number used FM4-7897-000 ?
    • Uniquer
      • Feb 2022
      • 30
      Only film not the assembly
      • Brian8506
        • 1664
        The films that come from China suck. At the least you should replace the film assembly. You can get rebuilt assemblies from Nationwide in Kansas.
        • Uniquer
          • Feb 2022
          • 30
          Its too expensive here to get fixing film assembly.. the fusee film is from CET ?? Bad?
            • 8164
            There's your issue.
            I guess you could try increasing the fuser temp in service mode, or set the paper trays to heavy etc.
            • Brian8506
              • 1664
              I don't use them but I know somebody who does and has had problems.
              • nicknt82
                • Nov 2011
                • 155
                Hello, Do problem happend after replace fixing film or toner?
                • Uniquer
                  • Feb 2022
                  • 30
                  Fixing film . The toner is ok
                  • nicknt82
                    • Nov 2011
                    • 155
                    If it is original toner, check fixing film and value on Service Mode, if it is compatible toner, replace deveop with good toner
                    • Uniquer
                      • Feb 2022
                      • 30
                      The problem solved by replacing hearing element( i think the problem was the heating element has to lines one is not working. The heat is not enough generated by one line)
                      thank you all for help
