ir8500
  • Robin (ACS Collective)
    • Nov 2021
    • 21
    ir8500
    Hello everybody and thanks for all the infomation shared here.
    I have been reading this forum for almost a year now and it has helped me through quite some struggle.
    So here is my newest quest:
    Canon ir8500 with a 0A0C.
    Before I have changed the bushings of my fuser roller and the driving gear.
    (They were completely rotten and particles affected the gear.)
    So I know there is no paper anywhere because there was no process like that going on.
    As far as I understand I now have a sensor PS10 missing power failure and afaik this one is part of the fuser unit next to the lower fuser roller.
    But this one is connected and clean.
    So are my thoughts actually right? Is it the right sensor?
    Any other ideas? Do I have to change the sensor?
    (Haven't found any easy opportunity to purchase one so far ...)
  • copier tech
    • 8144
    Re: ir8500
    If you suspect PS10 is faulty you can swap it with another sensor in the machine as a test (most are the same check the part numbers)
      • Nov 2021
      • 21
      Re: ir8500
      Thanks.
      I swaped it with PS16 and afterwards also with a completely new sensor.
      Same result: 0A0C
      So maybe the power cord is broken?
      But before I go on trying on this I would love to know if my guess that 0A0C means a power-on jam with external delivery sensor PS10 is actually right and if I identified PS10 correctly. Can anyone confirm?
        • Nov 2021
        • 21
        Re: ir8500
        Thanks.
        Same result: 0A0C
        [ATTACH=CONFIG]50911[/ATTACH][ATTACH=CONFIG]50910[/ATTACH]
        Haaa xD
        All good now. I mixed PS10 with PS6. My picture is wrong ^^
        • copier tech
          • 8144
          Re: ir8500
          Haaa xD
          Well done! yes there are a few sensors in that area.
            • Nov 2021
            • 21
            Re: ir8500
            Too soon.
            Now I am getting a long list of 0110, 010c, 010b, 010c, 0110 and again a 010c....
              • Nov 2021
              • 21
              Re: ir8500
              Fixed:
              I recognized this little fella was hanging to low and thereby jamming around every second sheet of paper.
              So I gently bent these two hangings with tongs in clockwise direction and here we go.
                • Nov 2021
                • 21
                Re: ir8500 - stapler blocked
                The stapler of our ir8500 stopped working - and its not because of a lack of staples.
                Are there any hints?
                  • Nov 2021
                  • 21
                  Re: ir8500
                  Now I am constantly getting E000069-0000 which I think I found on page 6-108 in the manual. Is this correct?
                  Additionally I got a hint saying "hvtr-value less than 300", which I do not understand.
