Canon iR1024 - Drops of water
  • luis1984bol
    • Nov 2011
    • 155
    [Misc] Canon iR1024 - Drops of water
    Hello:
    I have a problem with a Canon iR1024. The paper jams in fuser area. I have notice that drops of water form near the Fuser Unit.
    I had lubricated with silicone oil or Canon Grease, and in both cases I have the same problem. I changed the DC Controller and Power Supply PCB also.
    Does anybody can help me with suggestions or solution?
    Thanks!!
    Re: Canon iR1024 - Drops of water
    Originally posted by luis1984bol
    Hello:
    Thanks!!
    Moisture inside indicates wet paper.
    Humidity levels in the spot must be pretty high.
    Have the customer install a dehumidifier.
    • mojorolla
      The Wolf
      • 2627
      As Phil said, paper is soaked or environment.
      Most likely it's the paper, it hits the fuser and "flash steams" the moisture out of it. That Canon is a tiny little shit box with no fuser fan from what I remember...
      • luis1984bol
        • Nov 2011
        • 155
        Thanks for the answer.
        I had tried with 3 differents paper brands and it happens in customer office and in my place. There is no humidity in the environmient. I replace the fuser unit also.
        • copier tech
          • 8187
          Hello:
          Thanks!!
          Replace the waste water container its clearly full.
          • luis1984bol
            • Nov 2011
            • 155
            That was the first thing I have done!!..
            • Canuck
              Tech Specialist
              • 1713
              There is nothing in the machine to produce moisture. Enviromental print on service mode? Where are you located? As I said, machine won't produce water. If so I would patent it. Moisture in air or paper, or shitty ventilation around machine. I've seen this every year in my city for 35 years of repairing copiers
                Wet paper + 180f fuser = moisture inside machine.
                UNLESS there is a regularly watered plant above it!
                (Don't laugh had that on a LJ II decades ago)
