E602-1401 hdd error Canon ir-adv C3530i 2.nd
  • Primoz Primozic
    • Jul 2024
    • 7
    [Error Code] E602-1401 hdd error Canon ir-adv C3530i 2.nd
    Hi,
    We got problem with iradv c3530i 2.nd ver. machine wont upgrade we cant go to service mode or download mode. machine is poping out error E602-1401. We put new hdd in it and it is same error.
    Any help woud be great.
    thank you
  • bobburnsreb
    • Mar 2015
    • 229
    Hard Drive Format.pdf
    Hope this helps!
    • ADV COPIER
      Pemain
      • Nov 2022
      • 250
      Originally posted by Primoz Primozic
      Hi,
      thank you
      If u replace hdd with new one, you need reinstall the firmware boss
      Let's Drink our Coffee
      WhatsApp +62895325228383
      • Primoz Primozic
        • Jul 2024
        • 7
        We want to reinstal firmware but it is not posible. machine is not going to download mode or upgrade mode!
        • ADV COPIER
          Pemain
          • Nov 2022
          • 250
          Mainboard fail, go service center or replace
          • MOLICN
            • Mar 2024
            • 26
            如果无法进入下载模式和升级模式。您可以通过移除 flash 电子硬盘来报告错误吗?还是简单地报告 e748-2010 代码?
            如果可以报错,可以重写 flash 电子硬盘来解决这个问题。
            • zoraldinho
              teacher-guide-expert-guru
              • Mar 2008
              • 5007
              This gallery has 1 photos.
              • zoraldinho
                • Mar 2008
                • 5007
                Flash PCB failure. Take the same model flash PCB from another device. It will allow you to enter download mode so you can update. When you are finished, put the old one back.
                ps: Konica Minolta or Micopy? 😁
